Mallory Ignition trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2009, 03:33 PM
66Moostang's Avatar
On my Ford 302 in my '67 Cougar i have a Mallory electronic ignition and it worked great when i got the car and now sometimes it just stalls out of no where. But it starts right up again every time. A friend of mine said it definitely sounded like an ignition problem but i have no experience with any Mallory products or even any electronic ignition setups.
When it runs it runs strong. The rebuilt engine only has 10k miles and i drove it everywhere for a while. I just need to figure out whats going on here.
Old 08-06-2009, 03:44 PM
ericnova72's Avatar
More for Less Racer
What Mallory ignition is it, they make several different types -- points, breakerless electronic, or capacitive discharge??
wildthing's Avatar
Last journal entry: running fine
humm , i have a 68 cougar with a 302 .
ahh does it stall or shut off ? if it stalls , i would think fuel problem , like clogged filter. if it shuts off like a switch is turned then electrical. could be just a bad connect. the wireing in our cars is getting pretty old.
Old 08-06-2009, 03:49 PM
66Moostang's Avatar
i dont know what mallory it is.. i have a mallory coil and a mallory distributor.. i should..
sometimes it wont start up after it shuts off.. it isnt stalling.. its shutting off.. if it wont start up then i disconnect the battery cable then connect it again and it fires right up when i turn the key
Color codes for 2002 S10 Ignition switch tommer2 Electrical 1 10-22-2008 06:16 PM
Fried wire from ignition to soleniod? frankenvette Electrical 4 07-31-2008 02:45 PM
Ignition - No Spark DaytonaCoupe Electrical 3 07-04-2008 10:28 PM
MSD Vs. Mallory 71 c-10 Engine 6 01-07-2008 08:58 PM
ignition circuits jjpodlas Electrical 2 11-26-2007 10:41 AM
