Mallory Promaster Coil Test - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2012, 11:49 AM
64Joker's Avatar
64Joker
Are the following resistance readings within the acceptable levels for a Mallory Promaster Coil Part # 29440:
Product Suggested Resistance:
Primary: 0.6 ohms
Secondary: 12.3K ohms
My Test Results using a voltage meter:
Primary: 0.4 ohms
Secondary: 11.95K ohms
Additional Notes: The coil and resistor/ballast are about 10 yrs. old.
Ignition: Mallory HEI
Old 11-10-2012, 06:19 AM
The only real way to test a coil is with an output test on an ignition analyzer. If 10% of the windings are shorted, the resistance change will be very small and difficult to read with an ohmeter, but the output can be down a lot.
Unless it's an open circuit or dead short, resistance readings don't tell you a whole lot.
Your readings are very close to what is specified, if your car is running okay then it's probably good.
Mallory coil "start" wiring Q krehmkej Electrical 5 05-06-2011 05:06 PM
Ignition coil suspected of being faulty...how to test it? Steve-0321 Electrical 1 10-15-2005 04:40 AM
Ignition coil suspected of being faulty...how to test it? Steve-0321 Engine 3 10-15-2005 04:38 AM
Mallory coil vs. MSD Blaster 2 McDeuce Electrical 10 02-29-2004 07:57 PM
Mallory Promaster Coil w/ Standard Dist. kf6myv Engine 5 09-03-2003 09:57 AM
