Mallory Unilite Electronic Ignition Distributor - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2006, 06:06 PM
64Joker's Avatar
64Joker
Attempting to remove the rotor from a Mallory Unilite Electronic Ignition Distributor. I did not see any screws holding the rotor down, does the rotor just pop off? Tips ?? Thanks in advance.... Please see attached pics...
ID:	14982   Click image for larger version
Old 09-17-2006, 06:24 PM
powerrodsmike's Avatar
Wiki Edits: 161
Pull on the rotor and it will come off, they are pretty tight.
BE different....ACT normal.
Old 09-17-2006, 06:34 PM
64Joker's Avatar
64Joker
Follow-up ?
Is the black disk shown in the pic considered part of the rotor, or just the red rotor top? Where do I pull from? In other words, I need to see the points/? compartment.
Old 09-17-2006, 06:40 PM
Wiki Edits: 161
pull the red part, the black disc come with it.
Old 09-17-2006, 06:46 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Joker, you may want to inspect the advance mechanism on your Unilite. The pin for one of the advance weights broke and ended up shoving the rotor up into the cap. It was probably just a freak thing but I thought I'd give you a heads up.
ID:	14984   Click image for larger version
Ignition system info................ poncho62 Electrical 18 10-11-2008 10:10 PM
Mallory Unilite Ignition System loiselle Electrical 6 04-29-2006 06:03 AM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 05:11 AM
mallory unilite distributor rb8179 Electrical 1 07-14-2005 04:16 PM
Mallory Unilite Comp9000 distributor? Fairmont79 Electrical 1 01-13-2003 11:49 AM
