Mallory Unilite Ignition System - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2006, 08:16 PM
loiselle's Avatar
I have a street rod with a mild Chevy 350 V8 (275-300hp). I have a Mallory
Unilite distributor. It was recommended that I use a MAL-29219 coil since no
ballast resister was needed. I got it and after around 45 minutes with the
key on (engine not running) the coil heated up, cracked, and all the oil leaked out. Sheesh.
What is up with this? Anyone had this problem? Any recommendations since I obviously will have to get another coil and maybe ballast resistor? Thanks.
Old 04-26-2006, 09:12 PM
302 Z28's Avatar
The last decent Mallory ignition I owned was back in 1970 and it was a dual point. Sorry for your trouble, but I would cut my losses and go with an MSD.
Vince
Old 04-27-2006, 06:50 AM
Vince
I sold all mine on ebay as is in one big pile and use stock hei system been very reliable. Ed ke6bnl
Old 04-27-2006, 03:55 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Agreed..Toss it and go to a GM type HEI...For a mild street rod it will perform very well, last forever, and replacement parts are totally affordable and abundant..
The reason the Coil burned up most likely is it probably was a border~line OBF when you installed it, AND to leave any coil on for 45 minutes not running with the points Closed is pushing the envelope.
Essentially with the Power on and the points closed, your coil is a (on a high performance coil) heating element..or large heat sink. You have a primary voltage (with no resistance for ballast) of 12 volts, through a coil of wire that has a resistance of about 0.6 ohms..or a 20 amp heater to ground.
Next time you need the power on for that long, disconnect (or pull the fuse if so equipped) to the coil + side, and that won't happen.
If you go to the HEI system, about the only thing you need to do to make it a bit better, Is toss the old epoxy coil and install an oil filled one. It will help keep the temps down on the HEI body (module) and cap..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 04-27-2006, 06:50 PM
Last journal entry: 1949 Chevy PU 3/4t barn find
I have same set up, should I change?
I have a mild 350 SBC with a Mallory Unilite distributor with magnetic pickup. It also has a ballast resistor and a chrome ( dont know mfg) coil. I am installing a EZ wire harness. The harness has wiring instructions for this set up. What do you recomend switching too DOC? Please be parts specific. This is my weak spot. I may also need a diagram please. Also for a SBC in a 36 Ford pickup I would think it would have more nuts. Will this distributor swap help that?
Old 04-27-2006, 07:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
For a MILD street rod..or weekend warrior..non strip Cruiser..
Just get a STOCK pre 1980 (non confuser) HEI distributer, they all will fit the engine.. either order new about $200 bucks, or one can be had from a bone yard for around $25 bucks..
(put a new Cap, rotor, coil, module and pickup in it and check the end play if from the bone yard)
The wire is easy..One 12 gauge wire from the Ignition switch to the "BATT" terminal on the cap.., one to the tach (if used) from the "TACH" terminal and your done!
Doc
Innovations
Last edited by docvette; 04-27-2006 at 07:18 PM. Reason: I before E except after a 12 pack..
Old 04-29-2006, 07:03 AM
alot of bad about mallory
Also A mallory hifire VI a box is slightly stronger than the msd 6a and 60 dollars cheaper. Not that it matters much, figured i would let you know.
Which Ignition System Do you Prefer? And Why? docvette Electrical 73 12-14-2010 06:07 AM
Charging system info............... poncho62 Electrical 11 11-26-2005 09:53 PM
DI Ignition System Problem?? bluesman123 Engine 5 01-31-2004 05:12 PM
Mallory Unilite 53chev Engine 10 02-24-2003 06:43 PM
msd 7a to mallory unilite jimbobo Electrical 4 12-30-2002 05:09 PM
