Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Man could I use some advice
Old 08-01-2007, 02:14 PM
327NUT's Avatar
327NUT 327NUT is offline
If its the original '65 327 it should have the blow by or "road tube" as we used to call them coming off the back of the block. If its been rebuilt and equipped with a pcv valve then the tube could have been removed and a plug installed in the hole. Look at the back of the block below the distributor for any signs.......327's are GOOD engines!! edit....also if its a "powerslide" and you plan on changing it out, I would install a 700R4, 1800-2200 rpm conv. and 3.73 posi....it will scoot.
