Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mandrel bender
Thread: Mandrel bender
Old 01-31-2006, 10:29 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
If I were you I would buy prebent mandrel bends and weld them together., It looks tricker that way with nickel/nickel/nickel tig welds and you can mock it up easier. You will never bend that big of tube as tight as you need it for IC plumbing without spending $$$. Not anyway that I know of anyway. If you really want to, call a metal fabrication job shop and see if they'll bend up that tube on a real mandrel bender to your specs. That way at least you can say it is your design.
BE different....ACT normal.
