Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mandrel bender
Thread: Mandrel bender
Old 02-03-2006, 01:43 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
http://www.bendtooling.com/index.htm
They make dies. There is alot of engineering data there on that site you will find useful. They make dies there that will bend 8" diameter tube in a 16" centerline radius so I'm sure that the 3 1/2 " tubing you want to bend will be a cinch. They build dies from 1' on up so you can get all of your dies there. Hope this helps, mikey
BE different....ACT normal.
