Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Mandrel bender
Thread: Mandrel bender
  #22 (permalink)
Old 04-10-2007, 12:08 AM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
Wiki Edits: 161
That is a mandrel.
The JD2bender leaves no kink,, The dies as sold by JD are sized so it won't kink reasonably thin material.
Using a mandrel in that JD bender is a waste unless you get a smaller radius die to take advantage of the mandrel. Then you need to set up a frame on the back setion of the tube to keep the mandrel from pulling through the bend along with the material. Then it will need a way to retract the mandrel from the bent material. Real mandrel benders use a big hydraulic ram. That screws into the back end of that mandrel you pictured.
Try looking on ebay.
later, mikey
BE different....ACT normal.
