what would be the difference between a bender like this:
and a bender like this: the first bender is $80 and it comes with dies. The second bender is $300 and doesn't come with dies a degree ring or a handle. Would the second bender to mandrel bends? I am thinking if put a mandrel plug and ball inside the tubing it would help make some tubing that is "mandrel" bent |
I've got the bender on the top.Its only good for flat stock or solid round bar. It doesn't have tooling for tubes.
That second bender is the JD 2 bender that I put a link to over a year ago in this thread. it is a very good bender, worth every penny . That chinese bender at the top can't even compare to the JD2.
If you don't want to spend any money, Why don't you just pack sand inside of the tube and weld the ends up. You can get tighter bends in thinwall that way. Homebuilt mandrel benders don't work well. You can't get the balls out after you bend the tube.. I have tried it. . A true mandrel bender pulls the tube over the mandrel. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 04-09-2007 at 08:39 PM. |
with the jd2 bender. wht do u think? where can i find this insert? how bad of a kink does the jd2 bender leave? |
That is a mandrel.
The JD2bender leaves no kink,, The dies as sold by JD are sized so it won't kink reasonably thin material. Using a mandrel in that JD bender is a waste unless you get a smaller radius die to take advantage of the mandrel. Then you need to set up a frame on the back setion of the tube to keep the mandrel from pulling through the bend along with the material. Then it will need a way to retract the mandrel from the bent material. Real mandrel benders use a big hydraulic ram. That screws into the back end of that mandrel you pictured. Try looking on ebay. later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
You guys seem to be putting the guy down. I'm sure he knows he'll have to pull the mandrel through while bending the pipe.
Not only that I'd love to be able to do this myself at my house. |
Look at the date of this thread, you are 4 years too late!
| Recent Garage - Tools posts with photos |
| Tube or pipe bender? | Mikey_mike | General Rodding Tech | 5 | 02-15-2010 03:03 PM |
| Mandrel bender | Mikey_mike | General Rodding Tech | 8 | 01-10-2005 01:11 PM |
| tubing bender | Big Rig | Garage - Tools | 7 | 12-09-2004 08:17 AM |
| Pipe Bender Question | silm man | General Rodding Tech | 17 | 11-21-2004 04:30 PM |
| pipe bender? | flamedfordbronco | Engine | 14 | 04-21-2004 06:49 PM |
