Which manifold and carb for my Vette?
I have a 73 vette and have been given a 350 vortec engine with about 325 horse. I've been hearing I can't use my stock air cleaner but want the car to look as stock as possible. I've been searching the internet and getting mixed info. If I get a low rise manifold and use a lower air filter will I have enough clearance? I have a stock quadrajet on the car now that works great. Would I be able to use it? Thankful for any input.
RPM might be too tall
I am partial to Edelbrock carbs but have had good luck with Quadrajets. It's all in the metering rods.
regular performer intake and the Q-jet would be a good combo
Thanks Matt, I think I would be more comfortable tweeking on the Quadrajet.
Used to tweek Thermoquads on Mopars and they seem to be similar. |
most guys dont give Q-jets the credit they deserve
mostly do to lack of knowledge on tuning them correctly they are a great carb if done right |
I've had bad luck with Holleys. I think its just working with what your comfortable with.
Will my valve covers from my old engine work on the vortec heads?
This may help you. I put a 355 with vortec heads in my 77 corvette. I used a GMPP intake manifold 12496820 it is for a spreadbore "Quadrajet" carburetor. You need to go with a electric choke carb with this manifold. So your 73 carb won't work. I have a drop base aftermarket air cleaner. And it all fits under the stock hood.
And no your stock valve covers won't work but the C4 covers look good on vortec heads. With some pre planning work on the intake you can retain the distributor and ignition wire covers http://s147.photobucket.com/albums/r...eswap002-1.jpg |
I had the edelbrock performer on my 74 with a holley carb. I shut the hood and
Right in the center of the hood spider-ed the hood had to redo it. And i checked just wasen't done checking it and for some stupid reason i shut the hood to back it out of the garage. I stuck one of those old well the one in the pic below. I used it for awhile till it popped through the cab and it caught on fire and i threw it away. Whatever you put on it consider a good drop bottom plate for the filter. JMO And i don't recomend the type filter set-up in my pic to anybody Cole |
Read the following thread from the guys at the Corvette Action Center forum- http://www.corvetteactioncenter.com/...k-75-hood.html
You will need a drop base filter and a not-too-tall filter element and things will work fine. Keep the Q-jet- especially if it now works well. You may need to do some minor tweaking, but otherwise it, too, will work fine. If the new engine is going to stay below 5500 RPM, you can use the Performer and a taller filter element. |
Cole |
Start by measuring the available hood to air cleaner clearance of your stock corvette air cleaner on your stock motor. Now you have a baseline to work from. The performer rpm manifold will fit if you use the 60`s era 427 BBC air cleaner 1970 350 LT-1. corvette air cleaner. These have the lowest profile, allowing the most hood clearance.
| 1953-54 vette exhaust manifold | gentrys51 | Engine | 1 | 05-02-2006 11:09 PM |
| Intake Manifold and Carb | Ozz1967 | Engine | 9 | 12-29-2005 12:34 PM |
| 305 cam carb manifold | stickshift | Engine | 6 | 04-12-2005 03:46 PM |
| dual carb manifold | leftoverchrisac | Engine | 3 | 12-26-2003 10:07 PM |
| carb and manifold problems | schettler | Engine | 2 | 10-08-2003 06:39 PM |
