manifold change - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2012, 05:42 AM
manifold change
well i changed out the duce setup on my casket car for this polished crossram with 450 holley carbs.freshened them up with new kits etc.started up on the 3rd try. then i got a little brave and welded up these scoops something like what the tv/ movie car had. and since Barris or others dont like to give out info on such items i figured these came out pretty close
ID:	67373   Click image for larger version
ID:	67374   Click image for larger version
ID:	67375   Click image for larger version
Old 08-13-2012, 08:09 AM
RWENUTS's Avatar
Thumbs up!
Better to build your own than buy some everybody else has!
I've built a bunch of my own aircleaners too.
Want To Change 2barrel To 4 Barrel What Manifold ford3458 Hotrodding Basics 11 11-30-2008 11:42 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
Covert maunal column change to auto column change devious Transmission - Rearend 2 06-04-2007 01:10 PM
Did Chevy change the exhaust manifold bolt pattern on small blocks? STATUTORY GRAPE Engine 7 05-13-2005 05:34 PM
Won't change,wont' chang,won't change Samrupert Transmission - Rearend 6 01-11-2003 01:32 PM
