Early Hemi rocker shafts Hotrodders.com Free Speech Parts Auctions
Bid on a part, or auction one off -- help us defend against a frivolous lawsuit, and protect free speech online.
Click here for details.
Parts currently up for auction: 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, Early Hemi rocker shafts, "Power Rods" billet air cleaner top.
Model A Ford headlights
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 02-21-2005, 11:19 PM
wed68 wed68 is offline
New Member
Which Manifold for Chevy 355
I have the great pleasure of pulling the fresh chevy 350 from my Blazer again! With the 700 r4 tv cable geometry issues I was fighting on the performer intake I am considering going back with the stock intake. Will I lose much low end torque? The carb is the stock Q Jet and the cam is a Crane 260 very mild!
Oh by the way my conclusion on why I lost all mains and rod bearings on a fresh rebuild was that for some reason the oil galleries were either dirty or plugged and the grit in these wipped out the bearing within 20 miles! Sounds logical HUH! Anyway I am setting up now to pull the engine again and strip and recrank, yes I trashed the crank as well!
But I thought with the new oppertunity to rebuild I would consider doing things a little different like clean the galleries better and maybe put the stock intake back on! I also picked up a non ecm HEI didt today at the boneyard. I found several 3970010 engines that I was yearning for, I love the boneyard! Found several sets of ram horn exhaust manifolds but they were all cracked!
Thanks
Bill
Old 02-21-2005, 11:31 PM
rick458's Avatar
rick458 rick458 is offline
Wookie
re: Which Manifold for Chevy 355
Here is the site that will fix your TV cable problem
http://www.tvmadeez.com/
Keep your Edelbrock intake just fix the problem
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Which Manifold for Chevy 355"
Intake Manifold won't fit Andrew7dg Engine 15 01-21-2008 11:46 AM
Where is manifold vacuum port on Quadrajet 4mv? dr-data Engine 10 12-13-2005 04:41 PM
Weiand Manifold question Andrew7dg Engine 1 08-30-2004 12:03 AM
'97 crate 350 - what edelbrock manifold? THC3PO Engine 5 06-28-2004 04:56 PM
Which Intake manifold should i get for my 355? Mike_82 Engine 12 09-24-2003 12:25 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
