manifold install - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2004, 08:08 PM
RodFather's Avatar
I smell like a hotrod!
Last journal entry: windshield
manifold install
Ok I have read through a few of the forums, but I still have a couple of quick questions. I have a 350, and I am changing out the intake(with a used one no instructions). I will be using permetex instead of the end seals.
I am being told to put permetex around the holes the water runs through. I am sure I can tell which ones they are by the corrosion in them, but does anyone know which ones they are?
Second question... Should I just run a bead of permetex around those hole?
Any thoughts on this would be appreciated.
Old 10-07-2004, 09:27 PM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
The water ports are the ones at each corner (4) of the intake. I usually use a blue silicone on these...has never failed me yet.
Old 10-08-2004, 07:04 AM
RodFather's Avatar
thank you
Old 10-08-2004, 09:49 AM
302 Z28's Avatar
I would not use anything on those ports, all that is needed is a quality gasket. GM never used anything on them. The silicone will work great as the end gasket however. Let it sit for a while after you lay a bead down. You want it to start to set up before you place the intake on.
Vince
Old 10-08-2004, 10:02 AM
RodFather's Avatar
Thanks Vince...oh by the way the wiring went great.
Old 10-08-2004, 11:11 AM
302 Z28's Avatar
Glad to hear that. Did you change much on the drawing?
Vince
Old 10-08-2004, 02:17 PM
RodFather's Avatar
Yes, the drawing really helped. The hardest part was setting up the 3 wire alt. After looking at a couple ways to hook them up the easiest seemed to be running the excitor wire to both tabs (the 1 plug) and then basically hooking it up as a one wire. I have a friend who has been running this setup for many years now.
Old 10-08-2004, 05:11 PM
Lonestar's Avatar
Vince
I agree except for age begets imperfections. I have found that a very thin layer of blue around the water ports keeps the unlikely from happening.
Must remember to torque the bolts in even increments also.
