Manifold Restrictor inserts..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2012, 11:58 AM
wmwise's Avatar
De Oppresso Liber
Howdy guys, Well I had a dip***** attack today while installing my intake. Got everything installed and torqued, then I noticed on the work bench my restrictor inserts........
This is a very mild built chevy 350 that will only be used for some weekend crusing around town, so do you think it will hurt anything to leave it this way???
Thanks !
Old 01-01-2012, 12:12 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I wouldn't worry about it if it is opened up it will heat up faster for you and if closed/blocked it will just takes alittle longer for the engine to warm up that's all. JMO
Cole
Old 01-01-2012, 12:16 PM
techinspector1's Avatar
Wiki Edits: 326
Thanks !
You'll like it better without the restrictors. Only time I ever used them is for a drag motor where I wanted to keep the intake relatively cool. Street motors work better without them in my opinion.
Old 01-01-2012, 01:50 PM
wmwise's Avatar
De Oppresso Liber
Thanks guys ! I was thinking along the same lines
Have a great New Year
Bill
Restrictor plate and 2bbl carb BadMonkey Engine 3 02-28-2010 07:38 PM
nascars restrictor plates runn141 Hotrodders' Lounge 29 02-02-2007 04:40 PM
Aluminum foil okay??? (manifold restrictor) TroyMcClure Engine 4 07-05-2005 03:08 PM
HELP WITH Restrictor plate questions!!! Mrfixmaster Engine 11 08-03-2004 07:37 AM
Q-jet restrictor plate???? 455poncho Engine 2 12-13-2002 03:14 PM
