Manifold Vacuum - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-10-2002, 09:25 AM
Question Manifold Vacuum
I have a 95 355ci lt1 with a mild cam and various other mods. the vamuum is too low and the power brakes wont work properly as a result. Any ideas on how to correct this problem?
AJ
Old 10-10-2002, 09:43 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Vacuum reserve caister should do the trick. If you got a place to put it.
Old 10-16-2002, 08:50 PM
New Member
Wink
If you use a vacume resevoir Don't pump your breaks on hills. You'll lose your brakes
Old 10-17-2002, 02:56 AM
slider in wa's Avatar
Slider in Wa.
Post
I made mine. It cured the problem for me.
Slider in Wa,
Old 10-17-2002, 10:39 AM
1meancuda's Avatar
At a loss for words
Post
I've been reading something about vacuum being affected by the LSA of the cam. It could be that you have a narrow LSA??? Then again, putting in a resevior canister would probably be a better idea.
Old 10-17-2002, 11:46 AM
Post
yep, Definitly getting a Vacume Canister would fix your problem.
