manifolds and carbs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-20-2012, 02:20 PM
27TRoadsterguy's Avatar
Last journal entry: Frame Basics
manifolds and carbs
I am in the middle of installing 3 Weber 32/36 progressive 2 barrel carbs, each on its own tubular manifold, on my 6 cylinder 292 Chev engine. A friend of mine suggested connecting the three manifolds with "balance tubes" his logic was the engine will not be as finnicky to unbalanced carburetor fuel/air flow. Is this really necessary? I have seen this engine with three side draft carbs (DCOEs), and never any balance tubes. Balancing carb airflow is a matter of putting a vacuum gage on each carb, adjusting the carbs so the vacuum is balanced. My MG and my Healy and my motorcycles were all this way. Is there any need?
Carl
Old 02-20-2012, 02:57 PM
Carl
Your friend is onto one of the major reasons for balance tubes, the others being that any one cylinder can at least theoretically see the area of all the venturies, the third is a source of steady(er) vacuum for power brakes.
If those are not a concern and you don't mind balancing each carb like you do on your bike, no balance tube is fine.
Bogie
Old 02-20-2012, 03:51 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounds like a place to use a "Unisync" (unsure of spelling). It had (or has, if still made) individual manometers to give a visual reference on the carbs. All I'm seeing now is a different deal that's made by Edelbrock w/a single manometer that would be moved from carb to carb. It should also work, but doesn't look nearly as easy to use as what I used years ago on bikes.
FWIW you can also make a manometer for this (single or multiple), you can do a search for more.
Intake Manifolds & Carbs S10 Racer Engine 5 05-31-2010 03:49 PM
Tru Ram manifolds 35hotrod Engine 3 02-12-2010 09:41 AM
Holley Carbs VS. Edelbrock Carbs. KeithB123 Engine 3 01-12-2004 10:42 PM
Are these manifolds interchangeable? senor_limpio Engine 2 06-11-2003 09:04 PM
manifolds:old vs. new? ztoy Engine 4 02-27-2003 03:01 PM
