Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - manometer
Thread: manometer
Old 10-28-2012, 12:38 PM
ogre's Avatar
ogre ogre is offline
the 'Duracell Project'
manometers are usually used to test slight pressure variations like for filter racks in paint booths in the hotrod world
your measuring pressure not volume so use a small 1/4'' tubing
set up a U shaped hose on graph paper and use a dyed fluid to check differential pressure
but then you have to worry about how to calibrate it or
you can buy a new manometer from graingers.com for $40 or a used one off ebay for $5
if you buy used make sure you can get the right fluid for it as it will be calibrated for the specific gravity of the fluid
