manometer
Anyone have experience building one. What size tubing is preferred?
Buy a vacuum guage?
manometers are usually used to test slight pressure variations like for filter racks in paint booths in the hotrod world
your measuring pressure not volume so use a small 1/4'' tubing set up a U shaped hose on graph paper and use a dyed fluid to check differential pressure but then you have to worry about how to calibrate it or you can buy a new manometer from graingers.com for $40 or a used one off ebay for $5 if you buy used make sure you can get the right fluid for it as it will be calibrated for the specific gravity of the fluid |
I have a really nice vacuum gauge, but I just like building stuff on my free time. Is it water or thicker viscosity?
Does the amount of vacuum/pressure change what thickness of fluid should be used
distilled water
The guages are often read in "inches of water" - the depth of the "U" tube has to be something over 30 inches I believe. I've seen 1/4 and 5/16 aquarium type tubing used to make the "U".
One tube is exposed to atmosphere (with no air flow over the open end) and the other end exposed to the pressure you are testing - it is a comparitor device. You want to measure the difference in the height of the water on both sides of the "U". |
You can add some food coloring to dye it if you like. |
| All times are GMT -6. The time now is 10:11 AM. |
