Manual 4 speed something - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2004, 06:39 PM
ManfromKy's Avatar
New Member
I have a 4 speed trans that I got out of a 79 camaro. I was told that it was a Muncie. How do I find out?
Old 04-07-2004, 07:49 PM
302 Z28's Avatar
I doubt it is a Muncie, unless it was switched out. Can you tell what the case is made of? Or mayby post a picture?
Vince
Old 04-07-2004, 07:53 PM
poncho62's Avatar
Wiki Edits: 5
If the shifter shaft for the reverse gear is on the side cover, it's a Saginaw. If the reverse is in the tail shaft, it's a Mincie or T-10.
Saginaws are steel, Muncie and T-10 have aluminum cases.
Old 04-07-2004, 11:07 PM
Sandflea427SS's Avatar
Anything with a throttle
Count the bolts in the side cover going to the aluminum case. 7 for Muncie 9 for Super T-10
Old 04-08-2004, 04:41 PM
ManfromKy's Avatar
New Member
I found a transmission iddentification site. It looks like a saginaw tans. Would it be any good for strip \ street use?
Old 04-08-2004, 06:18 PM
poncho62's Avatar
Wiki Edits: 5
The Saginaw is a good street tranny. Has a good 1st gear. A muncie or T10 is stronger, but the Saginaw is a capeable trans.
Old 04-09-2004, 01:03 AM
Check here for Saginaw ID:
www.dandltransmission.com/saginaw.html
They also have some Muncie & BW stuff.
Old 04-09-2004, 01:16 AM
Saginawwws are very good trans...for easily going to the store for groceries.........take....it....easy.....!!!!!!!
