Manual to Automatic & E.Ts - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2008, 01:44 AM
oregon chevelle's Avatar
I am going to be swapping out the manual for an automatic so I can be more consistent at the track this year. The auto will be a reverse valve body TH400. I am also hoping to lower my times with this trnasmission as it should hook better and shift quicker than I could with the manual. I am not sure what the stall speed on the cnverter is so I am not sure how it will launch actually. The transmission is coming off a fairly mild 454 motor that I will use in another car down the road. So what do you all think? Will it run faster or not. I am sure it will be more consistent and that is the main thing in bracket racing anyway. My car ran a best of 13.74 at 99.74 last year with a 60ft time of 2.11. Cam is a single pattern 454 oft and 216 duration. I will also swap from a performer intake to a Holley Street Dominator and from an Edlebrock 600 to a Holley 650. I think they may be more than the cam needs? Heads are Trick Flow and are not being used much at all with the mild cam I have. That too will be changed eventually.
Old 01-31-2008, 07:12 AM
Will I ever get it done?
Last journal entry: Hood
A long time ago, I was always told that an auto car would have lower et's than a manual car (assuming the manual car was driven by someone who could shift it properly). But before giving an answer from old information, I decided to look at the NHRA indexes and records. In the quicker Stock classes (A/S, B/S, A/SA, B/SA, etc.), the indexes and records indicate you can plan on a manual car being about 0.05 seconds quicker than a auto car. With some fluctuation, this holds true until you get down around T/S T/SA. The lower class automatic cars are quicker than the manual cars. This would lead me to believe that in the lower the weight to horsepower ratio cars, the manual car would be quicker. Heavier, lower powered cars benefit from an automatic.
The thing is, and you already recognize this, et's don't win bracket races. Consistency does. If you can't consistently shift a stick car, you are going to be way ahead with an auto.
FYI, your et is equivalent to a R/S or a U/SA. 18.00 to 18.99 lbs. per horsepower and 20 or more lbs. per horsepower respectively.
Old 01-31-2008, 02:49 PM
Thanks for the input! I do not know what R/S or U/SA is?
Old 01-31-2008, 03:44 PM
poncho62's Avatar
Wiki Edits: 5
In theory, a standard tranny will be quicker than an automatic, provided the driver is perfect with the shifting. This is due to less slippage. A torque converter always has some slippage.
Those are stock eliminator classes.....Stock and stock automatic. The letter in front is the rating...."A" being the quicker and so on...due to various rules
Old 01-31-2008, 05:34 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
Why not a th350?
Old 02-01-2008, 06:04 PM
Thanks for the compliment. As for why not a TH 350? I already have a TH400 built from another car.
From automatic to manual trans Camaro71 Transmission - Rearend 7 12-18-2007 05:18 PM
manual or automatic trans 348chevy Transmission - Rearend 1 09-07-2006 08:29 PM
Which would be preferred for a 1927 Model T: Manual or Automatic transmission? jesseeee Transmission - Rearend 5 02-17-2006 08:39 AM
manual or automatic? Nos Transmission - Rearend 7 08-29-2003 03:06 PM
automatic to manual 97bird Transmission - Rearend 0 01-22-2003 10:43 PM
