Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Manual Brake Conversion - G-BODY
Old 07-29-2012, 03:48 PM
malibudave malibudave is offline
A Wilwood master cylinder will not work with the angle of a g-body firewall if the Wilwood master cylinder is bolted directly to the firewall. It physically bolts up, but there is a hole at the bottom of the master cylinder that regulates the fluid from one reservior to the other. When bolted directly to the firewall, the angle will let all the fluid run to the back reservior and the front reservior is left almost empty.
The Wilwood master should work on a TRZ or TNT adapter plates because these adapter plates correct the angle of the firewall and allows the master cylinder to sit horizontal (level) to the ground.
