Manual brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2009, 12:05 AM
Manual brakes
Guys help me out. I changed to a manual brake set-up. Without a great deal of stripping the dash down I can't get to my power brake pedal to modify it to go to manual brakes. I know I should drill a hole 1" above my power brake pedal hole to get better leverage for the manual set-up. Now if I keep the pedal like my power pedal what are the draw backs. Hard pedal? Or what??Thanks for the info in advance.
Thom
Old 03-10-2009, 03:48 AM
You'll have to push harder.
Old 03-10-2009, 04:25 AM
ericnova72's Avatar
More for Less Racer
What kind of car? GM pedals are easy to remove, just pull the clip and remove the main pin, then you can work on it on the bench instead of in the car.
Old 03-10-2009, 02:48 PM
Thanks for your reply!! It's a 2002 S10. Man I couldn't see how that sucker comes off!!!! I'll look again!!
Thom
Old 03-10-2009, 11:37 PM
406 bug's Avatar
9.82 @ 139mph
more leverage with less travel of the rod.
th350 delayed manual 1-2 upshift olympic73 Transmission - Rearend 2 09-13-2008 09:06 AM
Do I have power or manual brakes? BRSleeper2 Suspension - Brakes - Steering 14 09-12-2008 05:30 AM
manual brakes and steering F3RR3T Suspension - Brakes - Steering 3 09-17-2007 08:52 PM
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
streetrod brakes bigbadchev Suspension - Brakes - Steering 2 03-10-2004 06:02 AM
