Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Manual Choke doesn't function?
Old 03-26-2011, 02:10 AM
327NUT's Avatar
327NUT 327NUT is offline
Like I said you may have to experiment with the choke until you find the sweet spot for it to start. Let the engine idle for a few minutes until it warms up and then push the choke cable in. IF...you installed it correctly it should work.
