manual clutch for 1990 bronco - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-02-2010, 02:01 PM
i have a 1990 ford bronco with 302 and auto tranny. tranny went out and i want to convert it to manual shift. i have a tranny and t-case from 1983 f150. i was wondering if clutch pedal assembly from a 1973 f100 would work. i have no problem with minor fab work.
Old 10-02-2010, 03:07 PM
Wiki Edits: 31
you need the pedal assembly from a 1980- 1986 ( I think ) F-150/250/350 or Bronco with a non hydraulic clutch.. I'm pretty sure that is pretty much a bolt in. 1987 and newer, all the clutches were hydraulic, so that pedal assembly won't work for your conversion
Old 10-04-2010, 09:28 AM
thanks for the help found one down the road was just tryin to get away without spending any money
Issue with Ford 460 clutch onebadmerc Transmission - Rearend 1 02-22-2007 07:15 PM
htd clutch problem 2112jb Transmission - Rearend 2 02-16-2006 08:15 AM
Need Help w/ Clutch Chatter-2002 TA WS6 Josey Wales Transmission - Rearend 2 09-20-2003 08:59 PM
clutch linkage!!? chevyelc81 Transmission - Rearend 11 08-01-2002 07:46 AM
How to hook up torque converter clutch without a computer Roy Newton- exprotech Transmission - Rearend 3 12-28-2001 07:21 PM
