Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Manual conversion. Best 4 speed?
  #38 (permalink)
Old 08-19-2012, 06:41 PM
MadMacs MadMacs is offline
77 TA should be a hard linkage, not cable nor hydraulic, it will have a pushrod/ bell crank linkage. I make sure to check the gear cut to make sure its a true "rockcrusher". but 750 bucks is still a good deal on a m21 or m20. I would be sure to grab the transmission crossmember. Also i think pontiac bellhousing bolt pattern to block; is different than chevy, so that may not work for you. But Im not a pontiac guy so I don't know for sure.'
