Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Manual conversion. Best 4 speed?
  #58 (permalink)
Old 09-07-2012, 06:48 PM
RWENUTS's Avatar
RWENUTS RWENUTS is online now
The crank one is a pilot bearing or bushing.
THe linkage kit will be the same.
Might need a tranny mount too.
Crossmember to bolt tranny and mount to also.
Possible starter change too depending on whether you use a 153 or 168 tooth flywheel.
Buy a matched clutch kit too. You need to match the pressure plate to the throw out bearing. Raised finger plate uses a short throw out bearing and a flat finger uses a long bearing.
Depending on spline on output shaft you might need a different yoke for your driveshaft.
