Manual conversion. Best 4 speed? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-16-2012, 06:21 PM
bigdog7373's Avatar
Of course it's fast
Well i won't have to worry about it anyway. The transmission in the car is a muncie m22 rock crusher. Yes! Got a price of 750 if i pull it, 900 if he pulls it, for the tranny, pedals, and shifter. I have to get a bellhousing and clutch still since it has a pontiac motor and i have a chevy.
In addition to the tranny, shifter, and pedals, what else do i need to get from the car to make it work?
Thanks for the help so far guys!
  #32 (permalink)
Old 08-16-2012, 06:28 PM
vinniekq2's Avatar
if its not costing extra,take the bell crank,bell crank support ,adjustment rod, cross member mount,yoke,m-22 is different,,brake light switch,dont know if that car has a neutral safety switch,reverse light switch,bell housing (for future possible trade) console.speedo collar and cable,bolts,
  #33 (permalink)
Old 08-16-2012, 06:50 PM
bigdog7373's Avatar
Of course it's fast
I'll just take anything that's attached to the transmission. Is one of those parts attached to the engine? Will it work on my chevy motor?
also do you know if the clutch is hydraulic or cable operated?
  #34 (permalink)
Old 08-16-2012, 07:12 PM
RWENUTS's Avatar
Are you gonna pull the side cover to confirm it's a m22?
  #35 (permalink)
Old 08-16-2012, 07:18 PM
bigdog7373's Avatar
Of course it's fast
As long as it's a muncie i'm happy, but yes i'd like to know what i'm buying. I just look for the straight cut gears right?
  #36 (permalink)
Old 08-17-2012, 06:50 AM
You can see the M20/21 gear on the left vs. the M22
Only the M22 has the straighter cut
The M22 was available only with a 2.20 1st gear (should have a 3.73 or numerically higher ratio)
26 spline inputs and 32 spline outputs only mean the transmission was approximately 1970-1974 This is not M22 specific
All kinds of muncies have cases with drain plugs now
  #37 (permalink)
Old 08-18-2012, 10:47 PM
bigdog7373's Avatar
Of course it's fast
Picking up the transmission monday. I'd like to make a list of all the parts i should grab. Remeber his car is pontiac powered, mine's got a sbc. Here's whats on the list so far:
Tranny,
Shifter
All linkage
Bellhousing
Clutch
Clutch fork
Drive shaft
Cross member
Pedals
Now i know there's a few other things i'm missing so if someone could tell me what they are and where they are located that would be awesome.
Does anyone know if the clutch is cable or hydraulic?
  #38 (permalink)
Old 08-19-2012, 06:41 PM
77 TA should be a hard linkage, not cable nor hydraulic, it will have a pushrod/ bell crank linkage. I make sure to check the gear cut to make sure its a true "rockcrusher". but 750 bucks is still a good deal on a m21 or m20. I would be sure to grab the transmission crossmember. Also i think pontiac bellhousing bolt pattern to block; is different than chevy, so that may not work for you. But Im not a pontiac guy so I don't know for sure.'
  #39 (permalink)
Old 08-21-2012, 04:18 PM
bigdog7373's Avatar
Of course it's fast
Well time for an update.
Feast your eyes!
M22 rock crusher! Complete with hurst shifter, cross member, and drive shaft. All for....... 900 bucks Everything else was worn out looking so i left it alone. Will buy all new stuff to swap it in.
  #40 (permalink)
Old 08-21-2012, 04:33 PM
Last journal entry: It Will Work
It's a 26 spline from the early 70s. There are 2 rings on the input shaft, it may be a M20. I am not familar with the fine spline Muncies.
  #41 (permalink)
Old 08-21-2012, 05:02 PM
bigdog7373's Avatar
Of course it's fast
Yea hensaid he was pretty sure it was an m22. I wont be upset if it's not though. I'll have to pull the side cover and check it out. I only paid $900 for it with the shifter and cross member so even if it is an m20 i'll still be happy with it.
  #42 (permalink)
Old 08-21-2012, 05:15 PM
They always tell you it's a M22 when they own it or use to own it. It's like every old Mustang with a 302 in it is a Boss. If you see enough of them you can tell what it is by looking at it. They only used the fine spline Muncie for a few years and then it was replaced by a BW Super T10. There are websites that can tell you the ring count on the input shaft. The input shafts can be from a different transmission if someone worked on it but chances are it's what came on the transmission.
  #43 (permalink)
Old 08-21-2012, 05:28 PM
I would rather have a M20 it has a lower first gear. The M22 was used for 3:90 and up rear end gears.
  #44 (permalink)
Old 08-21-2012, 05:37 PM
You know a Muncie has had a hard life when you see one with broken ears that were welded back on. Seeing a used Muncie with broken ears is not uncommon.
  #45 (permalink)
Old 08-21-2012, 06:44 PM
Muncie I.D.
here's a link for Muncie Identification, one of the best in my opinion. Muncie 4 Speed Transmissions... so far seems to me you have a 26 spline d M-20. made in 1970 to 74. But you still need to pull the side cover to check the (cut) of the gears to know for sure. Also to V8-4spd... not all Muncie trans case ear were broken from torque abuse. A really common failure is using the bellhousing to transmission bolts to line up with the pilot bushing. Also improper grade of bolts. I used Grade 8 bolts, flats, and lock washers. But I always torgue them properly, I replace my lock washers at any teardown too. Also a transmission jack is worth it price ( in broken case ears ) in proper placing of your transmission.... as opposed to the wood block on a floor jack as we all have done
Gm - 22 Manual 3 Speed? qccbillo65 Transmission - Rearend 1 04-25-2012 06:38 AM
4-speed manual i.d babygene41042 Transmission - Rearend 3 01-13-2005 10:50 PM
Manual 4 speed something ManfromKy Transmission - Rearend 7 04-09-2004 01:16 AM
4 speed manual APACHEMAN Transmission - Rearend 5 07-22-2003 03:11 AM
Manual conversion nitrous_69stang Transmission - Rearend 2 03-18-2003 04:00 PM
