Manual Disc Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2009, 07:09 PM
Manual Disc Brakes
Well I am sorta planning the brakes for my 48 chevy and the front will be the disc brakes that come with the chassis engineering Mll kit, the rear is camaro drums. I am using the stock pedal and location and I was wondering if I could get some opinions on manual disc brakes. Would this be a good idea to the leverage provided by the stock pedal arm? What is the best style master to use? Thanks.
Old 04-27-2009, 08:53 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I had some of the same issue and am using a Ford master cylinder from a 76 Ford van that came with manual disk/drum brakes..you will need a pedal ratio of about 6 to 1 to make it work..
Sam
Old 04-30-2009, 11:11 PM
Helmets better than Brakes!
Hi!
Try ************** to keep you safe. Before griping your brake be cautious to where your helmets.
Last edited by powerrodsmike; 04-30-2009 at 11:31 PM. Reason: Advertising. Please see: commercial posting guidelines.
Old 05-01-2009, 06:06 AM
Will I ever get it done?
Last journal entry: Hood
I agree with Sam on the pedal ratio.
Also, don't forget to use a 2 psi residual valve on the disc side since the MC will be under the floor. The rears drums should get a 10 psi valve regardless of MC location.
Old 05-01-2009, 08:45 PM
powerrodsmike's Avatar
Wiki Edits: 161
1" master cylinder works pretty good for manual disc with a 6:1 pedal ratio, the pedal will be a bit stiff because disc brakes are not self energizing, but as long as you have enough pushrod travel to bottom out the MC with the available pedal travel, you should be ok.
Later, mikey
BE different....ACT normal.
Power boost drum brakes vs. disc brakes??? woodscavenger Hotrodding Basics 13 08-08-2007 02:07 PM
Weight of Disc Brakes vs Drum Brakes leejoy Suspension - Brakes - Steering 7 06-29-2007 12:41 AM
Front Disc Rear Drum Brakes bigjoedo Suspension - Brakes - Steering 2 07-02-2004 10:16 AM
11.5" disc brakes big...enough? tundrafiend01 Suspension - Brakes - Steering 4 06-11-2004 08:03 AM
57 Chevy Disc Brakes.. CHEAP PLEASE 30chevycoupe Suspension - Brakes - Steering 4 05-04-2004 09:17 AM
