Manual disc brakes
I am working on a 53 Studebaker half ton truck. It originally had 4 wheel drum brakes with a single reservoir master cylinder mounted under the cab.
My plans are to modify the system using the parts below. Unfortunately, there is not enough room to put a standard sized vacuum booster under the cab. I would like to leave the pedal assembly as it was originally. Long story short, I want to run manual brakes instead of power brakes to simplify installation and especially cost.
I would like to know if there may be issues with using this system manually.
There are small diameter booster/ master cylinder combos available, but I do not have the financial means to spend ump-teen thousands of dollars on this project. So far I have only bought a $55 cab mount strut besides a 1982 F150 parts donor truck for $200, and would like to keep it that way.
The parts I intend to use:
Master cylinder- dual reservoir from 82 Ford F150 (with power brakes)
Front rotors- 82 F150 (2wd)
Front calipers- 94 Chevy Lumina van with bolt on style calipers
Proportioning valve- 82 F150
Rear drum brakes- complete rear axle assy from 82 F150 (9" rear)
I fabricated a bracket to mount the master cylinder (minus the vacuum booster) under the cab in the same relative position as the OEM m/c, using the OEM brake pedal.
I am curious if there may be a potential problem in regard to pedal effort by eliminating the power brake booster that was in the F150 brake system.
My Galaxie has manual 4 wheel drum brakes, which work just fine, but I am not sure about manual disc brakes.
