Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - manual disc and drum system.
Old 06-24-2012, 10:29 AM
joe_padavano joe_padavano is offline
STOP! The very FIRST thing to concern yourself with is WHERE did you get the disks? If you are saying that you installed front spindles and disks from a 1980s G-body, DO NOT drive the car. The G-body spindles are not a bolt-in replacement for the 64-70 A-body cars. The ball joint studs have a different taper and will not seat properly in the spindles. THIS IS NOT SAFE TO DRIVE.
Did I mention that this is not safe?
Once you get the proper spindles and disks for an A-body, then simply get the correct master cylinder for an A-body with manual disk brakes - it was a factory option. Problem solved.
