Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - manual disc and drum system.
Old 06-29-2012, 12:04 AM
Canzus's Avatar
Canzus Canzus is offline
a red wool sock on his dinger
Originally Posted by S10xGN View Post
My car ('72 Maverick) came stock with manual drum/drum brakes and I swapped to 11" front discs, 11" rear drums (after changing to a 9" axle) and a Grenada disc/drum master cylinder...
Russ
Hey Russ, are you using the 15/16" manual brake master? The Power brake master is larger and will
give you a solid pedal with crappy brakes...
