you would need to hook your vacume line directly to a port on your intake. the brake booster needs lots of vacume to operate. you will need to install a porportioning valve, but i've never installed a power brake system unless i changed the front drum brake system to disc. do you have drum or disc on your truck now? if you don't i would recommend changing to disc brakes on the front so you would have proper braking.
