Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Manual to power brake conversion
Old 05-15-2003, 08:59 AM
jpd37 jpd37 is offline
I just installed a manual system on my 37 Ply and I installed a proportioning valve on the rear brake line immediately afterthe MC followed by a residual pressure valve. I added a residual pressure valve to the front line as well. I would think you should do the same thing. The power assist will require a vacuum connection and you should be set to go. Be sure none of the lines are kinked, leak or are rubbing against anything. Good Luck.
