Manual Rack and Pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 05:57 AM
Magnus_Jager's Avatar
Tow Chainer
Last wiki edit: Rebuilding an early Hemi engine
Last journal entry: cruise pics
Wiki Edits: 2
What are some donor cars/trucks with manual rack and pinion steering that would be beefy/large enough for a 3800# car?
Most of the kits I'm seeing are listing about 2800#.
This would be going into a 54 dodge with the original 241 v-8.
Old 08-03-2006, 09:26 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
i would think any 1/2ton pickup would work like a chev/GM box.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 08-04-2006, 06:03 AM
Tow Chainer
Wiki Edits: 2
Cool I honestly don't have much rack knowledge outside of the 4 banger beaters I've owned. I'll look into that.
Old 08-04-2006, 07:34 AM
astroracer's Avatar
It seems like this question is asked every other day here...
You really don't want to open this can of worms. It is not a simple job to "bolt on" a rack and pinion. Especially when you try to use a rack that wasn't designed for your non-rack suspension... There are a lot of design criteria that need to be met to have a rack work correctly with an existing non-rack suspension. Bump steer, ackerman and turning radius are just a couple that will haunt you mercilessly. Do a search here on "bump steer" and you will find a few threads that discuss this.
Read this and do some research...
http://www.longacreracing.com/articles/art.asp?ARTID=13
You would be much farther ahead to simply rebuild your current recirc. ball box and suspension. There is really no gain to be had with a rack and pinion that would out-weigh the problems you will create by trying to adapt one.
Mark
Old 08-04-2006, 07:59 AM
Tow Chainer
Wiki Edits: 2
Thanks for the link astro, it gave me alot more understanding in a short space. It also gave some more insight into the criteria nessesary to do this. Since I am currently running the original front suspension on this vehicle, the rack would likely be putting the cart before the house as any future upgrades such as a mirada front end would likely require a different set up.
Currently my 54 steering links take up a lot of space, and the steering box runs a hollow 1" round shaft from the box to the steering wheel that the horn wire goes down. The box is not large but that tube for a steering column is a bit of a concern. The system does work fairly well and tracked well prior to me diasassembling everything.
I think I will stick with what I have. Plus the look on the alignment guys face when they get to the kingpins and single concentric connecting the knuckle to the upper control arm will be priceless.
willys has rack and pinion davedeltadog Suspension - Brakes - Steering 5 03-31-2013 10:24 AM
Rack 'n pinion on an old Caddy? 67caddychris Suspension - Brakes - Steering 6 05-25-2006 08:06 AM
manual rack and pinion for rear steer needed Olds 69 Suspension - Brakes - Steering 7 03-25-2005 12:29 PM
Mustang-II rack & pinion mounting bushings?? NASCAR314 Suspension - Brakes - Steering 4 02-08-2005 12:53 PM
Mustnag II rack and pinion Echofive Suspension - Brakes - Steering 3 05-26-2004 06:26 PM
