Manual SBC Tranny? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2008, 11:36 AM
V8 Super Beetle's Avatar
VW makes it, Chevy shakes it..
Manual SBC Tranny?
I'm new to the models of transmissions for a SBC, so I need some help.
I'm considering going with a manual transmission for my build. I'm looking for pretty much the manual equivalent to a th350 (reliable, durable, and easy on the wallet). Must hold up the 400-450 hp. Can be a 3 spd. Something with over drive would be nice, but not necessary.
Any suggestions?
Thanks in advance!
Old 06-11-2008, 03:19 PM
Holder350's Avatar
Auto Parts Professional
Munci or a saginaw
If you can find a world class T-5 those are great but ratios are a bit off in the truck tannys..
you dont want a 3 speed.....trust me.....
EDIT: Here.....you might can use this.
http://www.nastyz28.com/chevy-manual...tification.php
Old 06-12-2008, 10:28 AM
Great info, thanks!
Old 07-06-2008, 09:52 PM
the dan's Avatar
83 chevy c10 long bed
Saginaws will not handle 400hp, though they are similar to the muncie with gear size, the pitch is different and the gears are not shimmed properly and do not mesh right. there is about 1/4 of the primary to cluster gear not meshing at all
muncies mesh perfectly and will handle 400hp all day
m22 rock crusher will handle even higher
manual tranny conversion DR132 Transmission - Rearend 5 02-01-2007 02:24 PM
Putting a 4-speed manual behind a sbc??? fiscus Transmission - Rearend 9 01-29-2007 10:21 AM
not hotrod-- manual tranny question... bigbadbowtie Transmission - Rearend 17 12-26-2006 07:01 AM
Pulling motor/ tranny 66 C10 66thom Engine 6 10-27-2003 09:46 AM
manual tranny swap chevyIIdie4 Transmission - Rearend 1 05-13-2003 09:09 AM
