Manual shift bearing inside of a crank????
Don't know if this is true or not that's why I ask. I had a guy tell me that in a manual shift SBC 350 truck motor there is a bearing inside of the crank that has to be taken out for a automatic transmission? Any help would be much appreciated, Rob.
So does this have to be taken out? If so, how would I go about taking this out? Do I have to replace it with anything? Thanks for the quick reply sbchevfreak.
yup, it's gotta go for an auto.. auto's don't use anything there
There's no reason to remove it, it's a pressed in bushing, no problem to leave it in place.
If you just want it out, you can get a small hooked puller or chisel one side of it. I've heard of people popping it out with compressed air...I don't see that happening.
Midnight Sun Street Rod Association |
You don't have to remove it to install an auto trans. It doesn't interfere. I remove the brass bushings by tapping with a 5/8 tap and turning in a bolt to pull it out.
Fill the whole cavity with Grease, Insert the punch/ dowel,+ Wack it with a BFHammer.... It'll push it right Out.... Another way to do it, If it's a Bushing, is to weld a little bead inside it,... Then let it cool,... It'll shrink it,+ it'll come right out with the tug of your finger... |
), as well.
If you decide to remove it anyway, the grease "hydraulic" method works fine (only way I've ever done it, actually), BUT be damn sure that you wear eye protection AND a glove or towel wrapped around the hand that is nearest to the bushing. Reason being, the grease will be expelled from any crack or crevice that may exist between the bushing ID and the tool used to drive it. This grease will come out under tremendous pressure, enough to penetrate flesh, never mind eyes. |
pilot bushing
on some fords I have had to pull the stick shift bushing, the Ford torque converter has a protrusion that fits in the hole in the crank. I bought a Vega with V 6 5 speed conversion cheap because the shop that did the high performance rebuild pulled the bushing and the guy that put the engine and trans back together didn't put in a new one The owner had shifting problems. paid for 2 new transmissions before he had enough
Ok guys, thanks for the help again. I'm probably just going to leave it in.
Ayuh,... Where's your sense of Adventure,+ the Desire to Learn,.... Pick a method,+ Do it... By doing it, You'll Remember.... just readin' about it here is nowhere near the Experince of Doin' it..... |
19cvy57man
Theres' no need to remove it so why waste the time?
| TH 350 1-2 Manual shift Feel | HarderTranz | Transmission - Rearend | 3 | 05-16-2006 09:20 PM |
| Trans seems to shift into neutral during the 3-4 (overdrive) shift | Rocketmann66 | Transmission - Rearend | 2 | 06-12-2005 10:21 AM |
| tiny little fish-scale-like flakes of bearing on bearing/journal | bullheimer | Engine | 2 | 04-16-2004 01:12 PM |
| Bearing spacers for 327 Crank???? | skz4u | Engine | 3 | 12-05-2002 10:08 PM |
| crank bearing play? | rebuilder? | Engine | 4 | 11-15-2002 05:00 AM |
