Manual Steering Box Lube - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2008, 08:10 PM
The service manual for my '64 Tempest calls for "all-season steering gear lubricant" for the manual steering box. Looking for reccomendations for current lubricants on the market........
Old 09-05-2008, 07:33 PM
powerrodsmike's Avatar
Wiki Edits: 161
Use regular wheel bearing grease.
Later, mikey
BE different....ACT normal.
Old 09-06-2008, 03:00 PM
I have used a whole tube of grease in a badly leaking box.
Mostly 85w90 rear end lube gets used, as it is about the same viscosity as 30 wt engine oil.
I wouldn't have a problem with using synthetic 20w50 engine oil either.
that's what is in one of my 63's now for 60,000+ miles.
power steering box with early hemi Frank Valentino Suspension - Brakes - Steering 5 12-18-2012 05:48 AM
Repair a leaky steering box gator412 Suspension - Brakes - Steering 8 06-01-2008 02:03 AM
525 Manual Steering Box OneMoreTime Suspension - Brakes - Steering 5 04-05-2008 01:40 AM
uh-oh. Wrong lube in manual steering box - what now? hotrodf1 Suspension - Brakes - Steering 6 07-17-2007 08:01 PM
1952 Chevy car power steering box what will work? Michael Bryan Suspension - Brakes - Steering 3 04-17-2004 10:15 AM
