Manual steering box on the street? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-19-2007, 02:04 PM
84Z 84Z is offline
Gas Raper
I'd like to lighten the front end of my street/strip car more by removing my powersteering. But I'm worried about turning with a manual steering box on the street. I have an 84 camaro, v8, a Grant gt steering wheel, which is 12-14" in diameter and I'm planning on running skinnies, probably 165 or 185. I won't have too much trouble turning at slow speeds would I?
Old 02-19-2007, 02:58 PM
Last journal entry: A few ongoing projects
It will likely be OK as long as the swap actually involves replacing the steering box with a manual unit. Little bit better ratio in addition to weight savings.
(a much better response than a couple of potential answers that first came to mind........like:
Man up and just do it
Back when I was young PS was for OLD people
By the way my dailey driver for the last couple of months has been a 57 Plymouth with a Hemi, 4 Speed and manual steering.
Old 02-19-2007, 04:13 PM
Perfectionist Procrastinator
Last journal entry: Moving along
My Nova has manual steering. Occasionally I need to put the car in the garage for a bit and work on it, and would drive a friend's S10 or, more recently, a Volvo.
Anyway, I never really minded the manual steering in the Nova. You have to really put your shoulders into it when in parking lots or doing a three-point turn, but it isn't impossible. But, going from the Nova to a (more) modern car with power steering is, I must admit, quite nice.
Think of it this way. You won't be able to hold a drink in your hand while steering without power assist because you'll need both fists to grip the wheel
Old 02-19-2007, 08:58 PM
The Maintenance Geek
Nah, if you're rolling, you'll be able to steer just fine, My
'63 F100 doesn't have power steering, it does have a 14"
steering wheel, and I can palm steer it in the parts store
parking lot...
K
Old 02-20-2007, 05:18 AM
I once drove a '66 cabover KW with an 8v71n and no p/s. Backing up to a loading bay I had to open the door and swing off the step to turn the wheel with both hands.
Prior to 1980 most cars here had manual steer, just turn the wheel. BTW, I 'spose your battery is already ine boot, your a/c gone and a whole lotta glass panels up front.
Old 02-20-2007, 06:06 AM
poncho62's Avatar
Wiki Edits: 5
My mom drove with manual steering in her 78 Zepher until she was 80.....I imagine you can handle it.
Old 02-20-2007, 09:45 AM
onebadmerc's Avatar
I need a bucket of arc sparks
You shouldn't have a problem steering it at all. I have a 67 F250 that has 31.50 X 15" tires on the front with manual steering and even my mom who is 61 can steer it fine at low speeds.
Old 02-20-2007, 06:55 PM
We have two Russiat truck's over here. I think they weight around 8000 lbs each and have a V8(aluminum) engine. It's a lot of work to steer them at low speeds. But hell yeah ... I'll get arm muscles (6)
69 Nova - manual steering box slack stratt134 Suspension - Brakes - Steering 4 08-16-2006 01:26 PM
Street Legal TV to Broadcast Video from NMCA Super Bowl Event at Route 66 nmrajames Hotrodders' Lounge 0 07-26-2006 10:53 PM
capping off a power steering box? tombo615 Suspension - Brakes - Steering 1 06-24-2006 07:35 PM
Steering box/Coupler (rag joint) Questions RObs71Nova Suspension - Brakes - Steering 1 10-27-2004 12:34 AM
Manual Steering Box sb72elcamino350 Suspension - Brakes - Steering 1 01-29-2004 11:07 AM
