manual steering conversion - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2002, 09:44 AM
Post manual steering conversion
I need a recommendation on how to convert a 73 El Camino to manual steering using factory parts. What parts would interchange?
Old 04-14-2002, 06:59 PM
Post
[ April 14, 2002: Message edited by: PAULWELDIT ]</p>
Old 04-15-2002, 06:34 AM
Question
you should be able to locate a manual stearing box for you vehicle at a savlage yard.then just change the stearing boxes.
Old 04-15-2002, 06:11 PM
elcamino72's Avatar
Gearhead
Post
I don't know why you couldn't, like OldBuz said, go to the boneyard and pull the parts you need off of a manual steering 73-77 GM A-Body. All the 73-77 A-Body's should be the same and fit in your Elky.
Old 05-06-2002, 09:04 AM
New Member
Question
first of all, why do you want manual steering? if you are just doing it because you want it, take parts off of an a body and fix it right up. but... if your'e changing it because it steers like a drunken buffalo, you need to look at your tie rod ends, ball joints, and suspension bushings. if it already was manual, and is fine, discard this message.
