Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - manual steering or power steering
Old 02-02-2007, 12:25 AM
pasadenahotrod pasadenahotrod is offline
If the truck's steering box is properly adjusted by the factory manual and lubricated and all other steering gear parts are acceptable and you're not running steamroller wide tires on the front you shouldn't have to worry about it.
The factory wheel on your truck is probably 17-18" in diameter where most replacement wheels are 14" or less. This will make a difference but you're a big boy and shouldn't have any problems adjusting.
