Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Manual Trans for 235
Old 03-03-2005, 03:13 PM
M&M CUSTOM's Avatar
M&M CUSTOM M&M CUSTOM is offline
Wiki Edits: 9
All three sound like good choices, the NP-A833 has the same gear ratios as the TH-700R4 auto, but all will hold up to the power the 235 will make.
I would look at the gear ratios and choose what rear gears you want and look at all of the variables to see if each will be the best choice for what you are looking to do.
