Manual Trans for 235
Hi all,
I am rebuilding/modernizing a 63 Chevy c-10 longbed as a daily driver. It has the stock 235 motor that im planning to keep and im looking to swap out the stock 3 spd tranny for a 4 or 5 speed ( something with syncro and o/d). I have been surfing around and I have found 3 trannys that look like some good options. 1) The NV3500 out of a 90+ s-10 or a 88+ full size truck. 2) The T-5 from 89-95 s-10 or camero V6 3) The New Process A833 4 speed from a 81-86 full size truck Does anyone have any experiance with any of these applications? |
All three sound like good choices, the NP-A833 has the same gear ratios as the TH-700R4 auto, but all will hold up to the power the 235 will make.
I would look at the gear ratios and choose what rear gears you want and look at all of the variables to see if each will be the best choice for what you are looking to do. |
Sounds good, ive been looking for my owners manual to find out the stock tranny and rear end gear ratios. Its going to be a daily driver/work truck so im lookin for economy and a decent freeway rpm.
You are not mistaken, I should have seen this but overlooked it.
Yes the NV-3500 has an integral bellhousing, and looking up the part numbers, there are nearly 10 different part numbers for the bellhousing section, which extends to the back of the webbed part on the side of the transmission. |
| stuck drain plug on manual trans | steffan_miller | Transmission - Rearend | 5 | 07-01-2004 10:15 AM |
| need help with manual trans ID | Scuzzy | Transmission - Rearend | 3 | 10-02-2003 12:27 AM |
| Anyone know about t-45 manual trans? reverse problem | Jason | Transmission - Rearend | 1 | 06-15-2003 02:14 PM |
| manual trans in my chevelle.... | dk01_99 | Transmission - Rearend | 5 | 02-15-2003 11:27 AM |
| 30 Model Manual Trans conversion | resolution2 | Hotrodders' Lounge | 0 | 05-28-2002 08:25 AM |
