-   -   Manual trans cooler? pump related (http://www.hotrodders.com/forum/manual-trans-cooler-pump-related-63837.html)
beemdubya 06-06-2005 12:29 AM
Im looking for an external fluid coolr for a manual trans.. so far i cant seem to find any for a manual only auto. i guess it would need an external pump but i am having a hard time finding them. anyone have any ideas? like this one.
http://i10.ebayimg.com/01/i/04/04/2b/80_1_b.JPG
MI2600 06-06-2005 08:09 AM
i've never heard of a cooler for a manual trans, but I'm sure someone has made or tried one. The manual trans is oil is so much thicker than auto trans oil, or even motor oil, I would think there would be pump problems. Also, I would think an aluminum manual trans case would dissipate heat fairly well.
Triaged 06-06-2005 09:05 AM
I have only seen them on endurance racing cars/trucks. You might want to search for rear end coolers because they are the same thing and you won't come up with so many auto trans hitts.
I have seen rear end coolers use a small dry-sump pump driven off of the pinion yoke by a belt. You may be able to do the same on the trans if it isn't a slip yoke.
Stock car products sells the pinion yokes with the pulley on them.
http://stockcarproducts.com/drysump1a.htm
http://stockcarproducts.com/drysump.htm
http://www.pegasusautoracing.com/gro...upID=TRANSCOOL
No one said it would be cheep :D
beemdubya 06-06-2005 12:15 PM
Yea the one from the third link is the right one.. thanks
