Manual trans cooler? pump related
Im looking for an external fluid coolr for a manual trans.. so far i cant seem to find any for a manual only auto. i guess it would need an external pump but i am having a hard time finding them. anyone have any ideas? like this one.
i've never heard of a cooler for a manual trans, but I'm sure someone has made or tried one. The manual trans is oil is so much thicker than auto trans oil, or even motor oil, I would think there would be pump problems. Also, I would think an aluminum manual trans case would dissipate heat fairly well.
I have only seen them on endurance racing cars/trucks. You might want to search for rear end coolers because they are the same thing and you won't come up with so many auto trans hitts.
I have seen rear end coolers use a small dry-sump pump driven off of the pinion yoke by a belt. You may be able to do the same on the trans if it isn't a slip yoke. Stock car products sells the pinion yokes with the pulley on them. http://stockcarproducts.com/drysump1a.htm http://stockcarproducts.com/drysump.htm http://www.pegasusautoracing.com/gro...upID=TRANSCOOL No one said it would be cheep
Yea the one from the third link is the right one.. thanks
| trans cooler position | brainsboy | Transmission - Rearend | 7 | 03-12-2005 03:50 PM |
| Trans cooler = lower engine temp | JUSTINH | Engine | 1 | 06-06-2003 01:40 PM |
| trans cooler | vega dog | Engine | 3 | 02-16-2003 01:46 PM |
| Turbo 350 Trans cooler | Redshiba | Transmission - Rearend | 3 | 09-02-2002 09:17 PM |
| Model A - Automatic to Manual Trans | resolution2 | Transmission - Rearend | 2 | 06-05-2002 07:42 PM |
