Which Manual Transmissions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2005, 09:03 PM
ok so im putting an ordinary small block in my car, i was thinking about which transmission i can use. im not really interested in automatic, and borg warner,muncie etc trannys are hard to come by in my area. what manual trannies can i hook up to the small block? i know this might sound like a dumb question to some but, i don't know the answer so i'll ask it, thats how we all learn
thx
Old 08-02-2005, 09:21 PM
small block?
Small Block from Chevy? Ford? Mopar? And most transmissions expecally from the muscle era are not big/small block specific.
Old 08-02-2005, 09:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Honestly
the tranny's I have seen lately in my area aer mostly toast and need a rebuild to be usable..which drives me to think tha tthe best deal would be go to jeg' or Summit and order out a new Richmond gear tranny..either the Super t-10 or the 5 speed would be my choice..
Comes new in a box and has the right bolt pattern and splines to bolt right up to a small block..
Money wise I think I fellow may be better off going that route..
OMT
Old 08-02-2005, 09:46 PM
sorry i guess i didn't mention it..but a small block chevy
Old 08-03-2005, 04:03 PM
broncoII88's Avatar
Do the right thing...
What kind of car? Yeah a richmond unit form summit is good. They offer a 4 speed, a 4 speed w/overdrive, and a 6 speed. You can choose what first gear ratio you want too!
Old 08-03-2005, 04:33 PM
the car is a model a. im just looking for anything i can shift gears through. can i use a tranny from a 50 chev car with 3 on the tree for example? or can i take a 5 speed off a s10 change a couple things and use it?
thx
Old 08-04-2005, 05:00 AM
Wiki Edits: 3
You can use anything that will bolt up in this case..Just that we generally reccomend the stronger tranny's such as the Richmond or a Tremec..Some guys use a Saginaw as those came in chev monza..I think you will need an adapter to use the S-10 tranny..but then the guys who put sbc engines in S-10 pickups can help with that piece..
OMT
Old 08-04-2005, 08:14 AM
MI2600's Avatar
Member# 3287
Since this is apparently a street car, probably your best, and least expensive, route would be a Saginaw 3 or 4-speed. There are a bzillion of them in junkyards. I recently sold a 3-speed for $35 and a 4-speed for $100.
Old 08-04-2005, 07:38 PM
broncoII88's Avatar
You might be able to get a bellhousing from www.advanceadapters.com You can have your 350 with basically whatever trans you want!
Old 08-04-2005, 08:11 PM
Where did you see a Richmond 4 speed w/overdrive? Their web site does not show it.
What's the story???
Old 08-04-2005, 10:06 PM
Chevy vegas and monzas are an easy find for wide ratio saginaw four speeds, this tranny will hold up if you don't abuse it much, the low first gear works well with freeway friendly rearend gears. The older chevy trucks used three speed saginaws and muncies as well as most 60's and 70's cars. Mid eighties chev trucks also had a 3speed+overdrive that was based on the old mopar 883 design that supposedly held up really well- this thans would also be a direct bolt on.
Personally I've got my sights set on a new Tremec TKO-600, hopefully it's as strong as they claim.
Old 08-05-2005, 08:44 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
Just about any run of the mill manual transmission can be adapted from most of the mainline manufacturers to your Chevy engine.
There was mention of the Borg Warner T-5 out of an S-10, one of them behind a 4.3 liter V-6 will directly bolt up to your V-8, but don't bother looking at one behind the 2.5 liter 4-cylinder or the 2.8 V-6, it WON'T fit and isn't worth changing things to make it hold up to the power of a V-8 anyway.
Old 08-05-2005, 06:24 PM
broncoII88's Avatar
It's not on the site? It was in the catalog! I swear!
Old 08-05-2005, 06:54 PM
awesome..i tried going into some s10 sites and looking for info about their trannies and they couldn't tell me anything. but if it will work i will run one of those, because i really don't want to run an automatic!
Old 08-05-2005, 07:43 PM
smallblocker2's Avatar
L79 327 5SPD S10 '65GTO
If you're looking into an S10 tranny, the 88-up 4.3l v6 trannies are the New venture 15-25-3500's. I have the 3500 in my truck, and it's been excelent. they bolt right up to a small-bigblock chev. fit the 168 tooth wheel and 12" clutch and stagger bolt starter. and are compatible with one or two piece seal engines.
The 3500's are also found in fullsize trucks, that's a small testament to they're strength as opposed to a BW T5
88-95, NV3500 use a hydraulic slave-fork-ball pivot.
96-up use an integral slave/throwout bearing.
I run a clutch for a 77 chev 4x4 4spd, that has matching splines, and the right bolt pattern for the early chev 168 flywheel.
My 5spd has lasted 3.5 years of abuse and missed 6grand 2nd gear shifts, and outlasted 2 diffs and 3 clutches.
I think they're pretty tough.
though I don't have much horsepower.
You could try V8S10.org as they put many smallblocks in front of S10 trannies.
Hope this helps man>
TH350 Manual Valve Question Pantload Transmission - Rearend 6 02-19-2006 01:48 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
700R4- full manual control powderbill Transmission - Rearend 4 02-11-2005 09:03 PM
high toque manual transmissions bigpimp2988 Transmission - Rearend 4 09-09-2003 05:59 PM
Manual Transmissions BenH Transmission - Rearend 2 07-19-2003 01:00 PM
