manual valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2009, 07:36 AM
manual valve body
I am looking at a th350 with a manual valve body. What is the advantage? I know you control the shifts but with the shift kit I have I can do that. Does the valve body make it instant and not have the lag time?
Old 11-01-2009, 07:57 AM
BOBCRMAN@aol.com's Avatar
A manual valve body will usually improve shift time. The disadvantage is. On the street, whatever gear you put it in is where it stays. No start in 1st if you put it in drive. Tries to start in third. No automatic up/downshifts.
Old 11-01-2009, 07:50 PM
ericnova72's Avatar
More for Less Racer
If you are really a gear head, this is not a "disadvantage" at all
Turbo 400 manual valve body Tbucit Transmission - Rearend 2 07-26-2006 08:38 PM
Full manual valve body Marcus Transmission - Rearend 3 03-01-2005 12:58 PM
GM fast burn heads batman09 Engine 1 10-26-2004 09:32 AM
auto shift kit in manual valve body? cadillacart Transmission - Rearend 0 01-11-2004 09:03 PM
Full Manual Valve Body TH-400 Chezelle Transmission - Rearend 3 06-13-2003 06:47 PM
