Manual Valve Body Install - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2007, 03:00 AM
happydad's Avatar
On a scale of 1 to 10 how hard is it to install a manual reverse valve body kit on a 86 700R in a Vette...I want to get rid of the TV cable Crap and this TCI kit has the options to do so...I've never installed one b-4...I've built engine's including this one but never messed with a 700R ..Any do's or don'ts I do have a FSM and can follow the trans info given in there..Just don't want this to turn into a nitemare... Any info would be helpfull
Old 08-26-2007, 09:38 AM
Crosley's Avatar
Wiki Edits: 1659
the TCi v-body may require some check balls not installed... I would hope their instructions would guide you on this.
With no TV cable the trans will probably operate at high main line pressure full time. This will cause the pump to wear slightly faster.
Have fun.
Old 09-01-2007, 11:45 AM
There's no check-balls at all and as Crosley stated, it has a fixed main line pressure. When I tried one, my line pressures were in excess of 240psi all the time.
It actually blew the circlip grooves of the front of my input drum. TCI said they had never heard of that happening before, so your milage may vary (my mileage was about 50 miles..)
Also I does exactly what you ask it to do with the shifter, including putting it into 1st instead of 3rd on a 2-3 change - My bmw tiptronic daily driver has you punch forwards to go up a gear, but the 700r4 with a bm ratchet shifter you punch backwards - so in the heat of the moment - its easy to punch the wrong way!
Old 09-01-2007, 02:52 PM
happydad's Avatar
Thanks all..Iread and reread the instructions and it does'nt appear to be that hard..I'll keep the FSM exploded view handy..Also I'm gonna keep the stock shifter and cut it down 3" and put a camaro ball on it...The TCI kit allows you to wire in the convertor a few diff ways..I'll go with lockup in 4th..What do you mean your milage was 50....
Old 09-02-2007, 01:47 AM
I mean i covered 50 miles, then it blew the drum out. It was a 1985 drum, so it may not of helped. I replaced it with a later drum (with the help of the guys on this board), eventually I went back to full auto - as the the full manual was fitted to track down a slipping 4th problem, as advised by my so-called gearbox expert - which actually turned out to be a mis-built servo.
photo of it here:
http://www.mez.co.uk/turbo7.html
Old 09-16-2007, 04:54 AM
happydad's Avatar
O.K I'm gonna do this today ..Can I still use the stock shifter till I decide what one I want?? I 'm not sure about the reverse valve in Trans effecting the shifting pattern of the shifter..I know the numbers will be reversed ie ND321 to N123D...Is that all..Every thing else will be the same no cable issues and such..Oh it's a 700R4 corvette trans
Old 09-16-2007, 06:31 PM
Crosley's Avatar
Wiki Edits: 1659
shifter should function..... you need to remember the shift pattern to use and not down shift accidently at a speed that could cause the car to lose control.
the reverse shift pattern is as you posted ... P R N 1 2 3 4.
good luck
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
G body with manual brakes - it works! - pics dh79 Suspension - Brakes - Steering 7 08-27-2005 10:55 PM
Best way to install valve cover gromits. and breather question? Jag Daddy Engine 1 05-03-2004 03:20 AM
Full Manual Valve Body TH-400 Chezelle Transmission - Rearend 3 06-13-2003 06:47 PM
