Manuel power brake proportioning valve - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-01-2009, 03:31 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by S10xGN
Calipers installed on the wrong side? The bleeder screw should be the high point (above the fluid inlet).
Russ
Good point, Which way is the bleeder valve pointing? Cole
  #17 (permalink)
Old 10-02-2009, 06:27 AM
Replace your proportioning valve with either an aftermarket unit or on from a 4 wheel disc equiped vehicle.Drum brake type valves limit rear flow and pressure due to the fact the drum brakes are self energizing and if pressure was equal to the front they would lock very quickly compared to the fronts.Had the same problem when converting my malibu to 4 whell disc.
  #18 (permalink)
Old 10-02-2009, 10:29 AM
Big_AL's Avatar
Russ
That was the trouble , my rear left caliper bleeder was not on the top that stupid thing made me loosing alot of time but its working
thanks to every body
chevy 350 jimang22 Engine 4 07-14-2007 03:49 PM
Bad advice lluciano77 Engine 28 03-09-2005 06:33 AM
proportioning valve question A/G WILLYS Suspension - Brakes - Steering 1 10-10-2004 07:38 AM
Changed jetting, power valve...still runs terrible BrackneyC Engine 3 04-05-2003 04:52 AM
Looking for a deal on power Brake booster,with pedal&combo valve for willys Harry Hut Interior 0 04-02-2002 01:36 PM
