Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - to many problems!!!!
Old 01-04-2012, 11:07 PM
Linez35 Linez35 is offline
first problem is im having carb problems, the nozzle that squirts out a stream into the primarys ive got a problem with it not spuirting out gas so it will run but it you can hardly give it any gas. but it will work sometimes it will pump it out. i took it apart and the accelerator pump looks fine. then when it does run good it give it a hard acceleration it coughs out acting like its running out of breath.. idk ive been having so many problems with my motor not running right i just need some good help...
