Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - MAP Sensor
Thread: MAP Sensor
Old 05-13-2003, 04:49 PM
NAIRB's Avatar
NAIRB NAIRB is offline Moderator
I would concentrate on looking at the IAC {Idle Air Controller} which should flare up upon start up and hold the idle at a higher speed for a 30 seconds or so. You should not have to give the engine any throttle during start up. Not to say this is the problem, but it sounds suspiciously so.
